I have exported a .wrl file from ArcScene, it is 7MB and comprises of 3D buildings, topography layer and master map. When I try and import to Rhino 5 it says “Error importing file…”. I need this base for modelling in Rhino, has anyone else had this problem?
Can you share the file here? Alternatively, you can upload the file to http://www.rhino3d.com/upload and one of our tech support will get back to you.
Sitemodeltopo.zip (1.1 MB)
Not sure why it does not import (into Rhino 5 and RhinoWIP). I was able to open it in Meshlab and reexport as wrl. This does import correctly into Rhino 5 and RhinoWIP: Sitemodeltopo_ed.wrl.zip (1.1 MB)
@tim do you have some knowledge of the wrl importer?
I have imported successfully from your file. Thank you so much for your help
I’ve added a YT issue to see if we can fix this: https://mcneel.myjetbrains.com/youtrack/issue/RH-42147
There are three invisible characters at the beginning of the version line, “#VRML V2.0 utf8”, that was causing wcsncmp to fail. Look at your file in a binary editor and you’ll see them. Windows 10 3d Builder will not open your file either until those 3 characters are removed. The next WIP of Rhino should read your file without modification.
RH-42147 is fixed in the latest WIP
@Tim, I also have this issue, but I can’t still import a .wrl file in Rhino5 although I deleted “#VRML V2.0 utf8” using a notepad. Should it work if I remove those words?
You can send me the file and I can have a look. There may be something simple, no guarantees though. If any fixes to code are made it won’t be in V5.
Tim
I should mention that deleting that entire line is not going to help. We use that line to determine which code to process the file with. It it’s not there I suspect we just bail. You need to use a binary editor to surgically remove the non-printing characters from the beginning of the line.
