I’m encountering an error when trying to create a solid using Sweep1. Could it be because the shape is too complex? Even after creating a surface and then attempting to generate the solid, I still get the same error. Please help.
Sweep1
rhino8 edu version.
SOLID_problems.3dm (174.6 KB)
You can select the profile curves, and use CurveBoolean to create a closed curve. Then extrude this profile along the path curve:
Thanks to you, it was well resolved.
