Enscape doesn't work properly when using RIR
Hi all,
Does anyone experience the same issue – When you are using Rhino.Inside.Revit, the Enscape functions are grey out. You can not do anything on Enscape except orbit the render view…
Every time when I want to render something, I have to restart the Revit and it will take me about 20 minutes to restart it…
I wonder if there is a work around to avoid this issue? Seems it is not possible to truly close RIR. RIR and Enscape are both the most frequent use plug-ins for my daily work,I have to keep restarting Revit to make sure I can use both plug-in and it waste a lot of my time…
Hi Jack, Is Enscape running in Rhino as well? The Enscape conflict is a known issue and will need to be addressed by Chaos group.
Hi Japhy, the Enscape is running in Revit, once I have both Enscape and RIR running in Revit, it would have this issue.
I don’t have access to Enscape, but do you have Rnscape plugin for Rhino loaded as well? this makes things a bit interesting Like Enscape inside Rhino that is inside Revit Running Enscape too?
It looks cool but loading Enscape multiple Times like this makes Rhino.inside revit crashes so I have to disable Enscape in Revit before using RIR
Hi tay,
I have instal Enscape in Rhino but I haven’t load the Enscape with Rhino when I am using Revit and RIR.
I just load the Enscape in Revit…
But you raised an interesting thing I haven’t about before – Maybe that’s why those software get confused and behave a bit haywire
So did you disable that pluging before starting rhino I side?
How to disable the Enscape for rhino?
In the plugins> plugins the didn’t ship with Rhino. Uncheck escape، restart Rhino and Give it a try
Is it what you mean? I try, I found that if I uncheck the Enscape plug-in in Rhino, I won’t be able to launch Enscape in Revit…
Can you click on the Revit UI? Probably requires focus on Revit.
Oh, I see, it works now. thanks tay!! :star_struck:
Wait, that was the solution all along, just disable the Enscape Plugin for Rhino ?
Any updates on this incompatibility ?
the issue persists…
Ohhhh no, I suppose Enscape is not willing to look into it, their forum posts are really vague and old now
We have to do something about it, it limits the installation of RIR to a very few people in my firm.
If there was something we could do in this case we would, the onus is on chaos to manage their dependencies in a way that plays nice with others.
Use this request to voice your concern, as far as I know, they are still incompatible
