Engineers, can you answer why this hinge hangs?
I’ve working on a 3D print project and I’'m trying to test a lid opening with a diagonal support that rotates up sliding in a groove/track then dropping into a slot deeper in the track. I’ve printed it, and it works and dosen’t. It slides correctly about 25% of the way, the hangs. It will continue with a little pressure applied to the diagonal support. I was hoping it would slide all the way to the stop. I come to Rhino from Art training, so my skills in how things work is mainly my common sense. Anyway, I suspect that as the support arm rotates the outside end is moving in a large arc. I have it sliding in a straight track. Is this the problem or am I missing something? If I was to make the track follow the arc within the structure, would that solve the problem? I’ve included the model and a ghosted image showing my thoughts.
HINGE_TEST_03.3dm (560.8 KB)
When you lift the lid you apply a force to the end of the strut. That force can be considered to have two components, one acting along the slot and one at right angles to it. You can see what proportion of the total force applies to each by drawing a line representing the total along the strut and lines in the two component directions to complete a triangle.
At the beginning of the slot, the force acting along the slot is a significant part of the total, so it pushes the end of the strut sideways. However, when the strut is perpendicular to the slot, the entire force is pulling along the strut and there is no force to push the end sideways, so it won’t move.
In reality, the strut won’t get all the way to perpendicular because there is friction in the system and some of the sideways force needs to be used to overcome it, so you reach a point where you have insufficient force left to move sideways. That’s where the strut sticks.
Making the slot into an arc won’t help. There are various ways of adding some extra sideways force (e.g. a spring) but anything that makes opening the lid work better will also make closing the lid harder. You have to consider whether those compromises are acceptable.
Regards
Jeremy
Jeremy, thanks so much for the explanation! I actually understand it now. I did recognize that as I got closer to perpendicular, that was where the problem manifested itself.
Thanks for correcting me on the arc theory. Tough making the track an arc would have been a good Rhino exercise for me, wasted time is not.
I did think of adding a spring, or at one point replacing the strut with a gas/spring strut, but they don’t come that small, (110mm ±) and I hoped to 3D Print all the parts of the contraption with the exception of the fasteners.
I’ll have to give this some more thought.
If you raise the base pivot of the strut and limit the movement of the top to somewhere short of perpendicular like this red one
you might get it to slide all the way. With a detent slot at the end, similar to your original, it should stay open and, provided the top isn’t too heavy it should be sufficient to support it.
Raising the bottom pivot gains you a little more angle.
Another solution, and one that is commonly used, would be to replace the sliding strut with a strut hinged in the middle and sprung so that, as the lid opens, the halves rotate over centre and shoulders on each part butt together to provide support. The joint must be pushed in back past centre by the user in order to close the lid, so the hinge is only viable if it can be positioned where easily reached while holding the lid.
Thanks. Did not think of option one. Regarding option 2, I had modeled the hinge (blue) but it started getting to the point that I was near the limits of possible widths. I did find this, with the widest part at 10mm which might be viable.
Amazon.com ?
