Hi;
In this sample,if I want to enable the displayconduit when the PlugIn load,and the it draw the mesh after mesh get a value by CRhinoGetObject.
How cant I do this, is it some sample?
Hi;
Just curious, why would you not want to create your conduit on demand?
What is you conduit supposed to provide?
– Dale
Hi @dale;
I want to draw some object after the PlugIn command end of run.
So that, I do like this:
//DISP_H.h
#ifndef DISP_H
#define DISP_H
class CConduitDrawColorMesh : public CRhinoDisplayConduit
public:
CConduitDrawColorMesh();
~CConduitDrawColorMesh() {}
bool ExecConduit(
CRhinoDisplayPipeline& dp, // pipeline executing this conduit
UINT nChannel, // current channel within the pipeline
bool& bTerminate // channel termination flag
const ON_Mesh* m_pMesh;
#endif
#include "StdAfx.h"
#include "DISP_H.h"
CConduitDrawColorMesh::CConduitDrawColorMesh()
: CRhinoDisplayConduit( CSupportChannels::SC_CALCBOUNDINGBOX | CSupportChannels::SC_POSTDRAWOBJECTS )
bool CConduitDrawColorMesh::ExecConduit(
UINT nChannel,
bool& bTerminate
// Get the rhino viewport attached to the display pipeline...
CRhinoViewport& vp = dp.GetRhinoVP();
// Determine which channel we're currently executing in...
switch( nChannel )
case CSupportChannels::SC_CALCBOUNDINGBOX:
if( m_pMesh && m_pMesh->IsValid() )
ON_BoundingBox bbox;
m_pMesh->GetTightBoundingBox( bbox, false );
// Now adjust the channel attribute's bounding box with the accumulated one...
m_pChannelAttrs->m_BoundingBox.Union( bbox );
break;
case CSupportChannels::SC_POSTDRAWOBJECTS:
if( vp.DisplayMode() == ON::wireframe_display )
dp.DrawWireframeMesh( *m_pMesh, RGB(0,0,255) );
else
CDisplayPipelineMaterial mat;
dp.SetupDisplayMaterial( mat, RGB(0,0,255) );
dp.DrawShadedMesh( *m_pMesh, &mat );
break;
return true;
//sample_dispalyPlugIn.cpp
but in the cmdsample_dispaly.cpp
How cant I assign?
In your sample, conduit is a variable you create on the stack. Thus, when the OnLoadPlugIn function finished, the variable is thrown away.
– Dale
