guido
May 8, 2019, 11:49pm
#1
This is an old topic but there hasn’t been an update on it for a while so I’m posting it again.
Hi, I just ran into an unexpected bug with clusters that is causing some headaches. Namely, I have some intentionally empty branches on some of my inputs that are being removed when inside the cluster.
Oddly, those branches are only being removed when I am inside editing the cluster, which is actually causing me to get different results when I am outside vs inside the cluster. Outside of the cluster, my outputs are behaving as I intended, but while inside my results are all garbled because the …
all looking good from outside, but…
inside empty paths are missing.
Clearly, this only becomes a problem for previewing an output when working inside clusters but it’s still pretty critical.
