Hey guys, how can I get elevation view in perspective mode? I want to use it for vray rendering. If I render directly from the Rhino default side view there is no sunlight and all that. Any helps would be appreciated, cheers!
one way is make a copy of side view ports and than change projection from parallel to two point perspective, i hope it’ll give you what you want:+1:
