Hi! I am curious if element tracking and error mode - that are available on all creation components - are available for C# / Python components in some library? I would like to investigate the creation of 1D Analytical Members (new in Revit 2023) using GH, but before diving too deep, I wanted to know this.
What I got so far in Python, but this overwrite every new member when changing an input:
"""Provides a scripting component.
Inputs:
x: The x script variable
y: The y script variable
Output:
a: The a output variable"""
import clr
clr.AddReference('System.Core')
clr.AddReference('RhinoInside.Revit')
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
import System
import Rhino
from Grasshopper.Kernel import GH_RuntimeMessageLevel as RML
# bring in the node-in-code handle
from Rhino.NodeInCode import Components
# Revit API
from Autodesk.Revit import DB
from RhinoInside.Revit import Revit, Convert
doc = Revit.ActiveDBDocument
def show_warning(msg):
ghenv.Component.AddRuntimeMessage(RML.Warning, msg)
def show_error(msg):
ghenv.Component.AddRuntimeMessage(RML.Error, msg)
def show_remark(msg):
ghenv.Component.AddRuntimeMessage(RML.Remark, msg)
revit_curve = Convert.Geometry.GeometryEncoder.ToCurve(curve)
t = DB.Transaction(doc, "Create Analytical Members")
t.Start()
analytical_member_before_commit = DB.Structure.AnalyticalMember.Create(doc, revit_curve)
t.Commit()
analytical_member = analytical_member_before_commit
