eleFront Beta Update to 5.0.5
too bad I can only give ONE heart to a post.
Thanks Keyan.
The solution is now obvious. I just needed to install 4.3.0
Hello @krahimzadeh .Just want to let you know that this problem (Insert Block not detecting names) -
still persists on the full Elefront 5 release. Moreover, this problem now also affects the Reference Block by Name component. I used to bypass this problem using Reference Block by Name however it appears it doesn’t work too.
Hello @krahimzadeh , here are file samples of the problem. It’s really, really weird, because different problems arise when I try to replicate it in another file.
Elefront 5.1.2 Problem - Reference block by name.gh (10.8 KB)
Elefront 5.1.2 Problem - Reference block by name.3dm (17.9 MB)
Thanks for the info and the files, I will see what I can do. Sorry for taking so long, I was on vacation, then at a conference, etc. etc. Hopefully next week I can look into it.
Thank you and no worries, @krahimzadeh.You guys are doing a great service for the Rhino/Grasshopper community with this plugin.
