Something is wrong with my text size for the stair step number labels that are generated automatically. Is there a way to edit them? or at least hide them?
Hi @seflorance, the stair-step numbers take the settings of the current Rhino’s dimension style, so you can edit them from there (Options > Document Properties > Annotation > Dimension styles).
If you wish, you can also hide the numbers from the stair styles dialog (vaStairStyles command)
The arrow should be visible as long as you are showing that stair in plan view representation. If it’s not working for you, please send us that file to visualarq@asuni.com and we will revise if there is any bug.
