Hi, is there any way it can be integrated to Ecommerce? can the chosen parameters on the frontend get posted or submitted into the backend?
Hi Eric,
Yes. With a Designer Plus plan or above, you get access to our Viewer API, which can be used to connect your ShapeDiver model to a custom frontend. You’ll need a bit of web development knowledge to complete this step. I recommend reading our step-by-step guide on getting started with our platform, as this clarifies many of these concepts:
If you’re interested in learning more about our Viewer API, you can check out this video tutorial series:
Hope this helps.
