I am building a command to raise/lower vertices of a mesh on every mouse click. I would like to visualize the region which includes the selected vertices using a circle. I thought DynamicDraw would do this by actively drawing a circle as I hover over various regions, but for some reason it doesn’t work. Does anyone know what I’m doing wrong in this code?
Thank you in advance!
Shahe
var go = new GetObject();
var brush = new GetNumber();
var height = new GetNumber();
bool pushUp = true;
go.SetCommandPrompt("Select mesh to modify");
go.GeometryFilter = ObjectType.Mesh;
go.Get();
RhinoGet.GetBool("Push up or push down the vertices?", true, "down", "up", ref pushUp);
if (go.Result() != GetResult.Object)
return Result.Cancel;
brush.SetCommandPrompt("Set brush radius");
brush.Get();
if (brush.CommandResult() != Result.Success)
height.SetCommandPrompt("Set movement height");
height.Get();
if (height.CommandResult() != Result.Success)
double radius = brush.Number();
double myHeight = height.Number();
var rhino_object = go.Object(0).Object();
if (!(rhino_object is MeshObject mesh_object))
Mesh[] m = mesh_object.GetMeshes(MeshType.Any);
Mesh myMesh = new Mesh();
myMesh.CopyFrom(m[0]);
Point3d[] verts = myMesh.Vertices.ToPoint3dArray();
while (true)
var gp = new GetPoint();
gp.Get();
gp.DynamicDraw += (sender, e) => e.Display.DrawCircle(new Circle(e.CurrentPoint, radius), Color.Red);
if (gp.CommandResult() != Result.Success)
return gp.CommandResult();
Point3d currentPt = gp.Point();
Sphere myActiveSphere = new Sphere(currentPt, radius);
Brep sBrep = myActiveSphere.ToBrep();
Dictionary<int, Point3d> selectedPts = new Dictionary<int, Point3d>();
for (int i = 0; i < verts.Length; i++)
if (sBrep.IsPointInside(verts[i], 0.01, true))
if (pushUp)
verts[i].Z += myHeight;
else
verts[i].Z -= myHeight;
selectedPts.Add(i, verts[i]);
foreach (var key in selectedPts.Keys)
Point3d pt = selectedPts[key];
myMesh.Vertices.SetVertex(key, pt);
Guid mesh_guid = rhino_object.Id;
doc.Objects.Replace(mesh_guid, myMesh);
doc.Views.Redraw();
