Can someone provide simple example how to do dynamic draw of a plane, based on 3 points please? My knowledge in this area is very poor.
I’ve seen some examples how to do the lines, but still, can’t figure out how to use it for plane.
A plane as a surface or a plane as yeah. a plane xD
As a plane from 3 points.
Is this what you want to do?
Rhino.Geometry.Plane plane;
Rhino.Input.RhinoGet.GetPlane(out plane);
No, this is not what I’m looking for.
I need to dynamically draw maybe even not a plane, but projected curve, before I will accept final result of projection. SO I have something like this:
Rhino.Display.DisplayPipeline.DrawOverlay += (sender, e) => e.Display.DrawCurve(projected[0], Color.AntiqueWhite);
but it doesn’t redraw projection result whenever I move the mouse. So how can I acheve this? How to dynamically see projection result before accepting final 3rd point?
Here is also piece of ugly not working code, that I have created, can any one help with this please?
const ObjectType geometryFilter = ObjectType.Surface;
GetObject go = new GetObject();
go.SetCommandPrompt("Select surfaces");
go.GeometryFilter = geometryFilter;
GetResult res = go.GetMultiple(1, 0);
RhinoObject rhinoObject = go.Object(0).Object();
var brep = rhinoObject.Geometry as Brep;
RhinoApp.WriteLine("The {0} command will add a line right now.", EnglishName);
Point3d pt0;
using (GetPoint getPointAction = new GetPoint())
getPointAction.SetCommandPrompt("Please select the start point");
if (getPointAction.Get() != GetResult.Point)
RhinoApp.WriteLine("No start point was selected.");
return getPointAction.CommandResult();
pt0 = getPointAction.Point();
Point3d pt1;
getPointAction.SetCommandPrompt("Please select 2nd point");
RhinoApp.WriteLine("No 2nd point was selected.");
pt1 = getPointAction.Point();
var line = new Line(pt0, pt1);
var curve = line.ToNurbsCurve() as Curve;
var tolerance = 0.01;
Point3d pt2;
getPointAction.SetCommandPrompt("Please select the end point");
getPointAction.SetBasePoint(pt1, true);
RhinoApp.WriteLine("No end point was selected.");
while (getPointAction.Get() != GetResult.Nothing)
pt2 = getPointAction.Point();
Vector3d vector3d = new Vector3d(pt2.X - pt1.X, pt2.Y - pt1.Y, pt2.Z - pt1.Z);
var projectedCurves = Curve.ProjectToBrep(curve, brep, vector3d, tolerance);
foreach (var projected in projectedCurves)
//doc.Objects.AddCurve(projected[0]);
doc.Views.Redraw();
These type of drawing is better off in a custom GetPoint
class that overrides OnMouseMove
and DynamicDraw
See if this example is of any help.
https://github.com/dalefugier/SampleCsCommands/blob/master/SampleCsOrientPerpendicularToCurve.cs
This will do just fine, thanks
I there a current version of this example?
Here is the source:
Does this help?
yes, thank you. At some point I’m hoping I can quit copying and start understanding. Is there a hidden c# noob section?
Does this help?
– Dale
