Create line on a plane
I’m using rs.PlaneFromPoints to create a new plane and want to draw geometry, for example: a line, on that plane. Can someone tell me how to do this?
Rhino 7 using RhinoScript or Rhino Common
Eric
Hi Eric, please see below:
import Rhino
import scriptcontext
def DoSomething():
    plane = Rhino.Geometry.Plane.WorldZX
    line = Rhino.Geometry.Line(plane.PointAt(10,10,0), plane.PointAt(20,20,0))
    scriptcontext.doc.Objects.AddLine(line)
    scriptcontext.doc.Views.Redraw()
DoSomething()
or like this:
def DoSomething():
    plane = rs.WorldZXPlane()
    point_a = rs.EvaluatePlane(plane, (10,10))
    point_b = rs.EvaluatePlane(plane, (20,20))
    line = rs.AddLine(point_a, point_b)
DoSomething()
_
c.
It is also possible to dynamically draw points or a polyline constrained to a plane via RhinoCommon, but it takes a bit more coding…
This will work for me thank you!!
Eric
Are there any code examples of this workflow? Goal here is to construct a 3D assembly of parts based on data so I was thinking create polylines which I will subsequently extrude to create the components of the assembly. Something like Solidworks where you are sketching on different planes and extruding the sketches into solids.
Eric
