My name is Frits and I apologize for my bad English.
Please give me a example how to write rebuild … so it will use allways U75 and V45 when I presse the button. (See the picture)
Thank you in advance
Something like this should work:
! _SelOpenSrf _-Rebuild _UPointCount=75 _VPointCount=45 _Enter
–Mitch
Hello Mitch,
It works perfect! Thanks.
Please tell me if you can, where can I find this kind of info?
Upointcount for instance I cannot find in help
Hoi Frits,
When a command pops up a dialog box to tweak the options, you can run the command with a dash in front to view the command options on the command line. In this case:
-Rebuild
A macro is then just the combination of the command and the options that you want. There are several places where you can find more information. The following can be a good start:
http://wiki.mcneel.com/rhino/basicmacros
Whow…,
Tnx, there opens up a new world for me!!!
Tnx both Mitch and Wim
