DupBorder for Mesh C++
I know how to do DupBorder of a Brep (it is nicely demonstrated in the Knowledge Base), but I need to do that for a mesh…and I`m not sure what is the easiest way to do it…any suggestions?
Thanks!
Milos
To find naked edges on a mesh (which I guess is what you want), take a look at GetMeshEdgeList in opennurbs_mesh.h, esp. the remark on line ~1770
      * If edge_type_partition[3] <= ei < edge_type_partition[4],
        then edge_list[ei] is a boundary edge of exactly one mesh face.
        These are also called "naked edges".
thanks. So i basically call the GetMeshEdgeList function and examine the “edge_list” to see if its value is between edge_type_partition[3] and edge_type_partition[4]. Two things confuse me:
  1. “edge_list_partition” and “edge_type_partition” are both used in the description for what seems to be one array…are they the same thing?
  2. edge_list is a structure of two ints as i see (int i , int j)…I I am guessing those are the indices for the m_V at the start and the end of the edge…but do I compare them both to the edge_type_partition? Only if they are both between [3] and [4] means that the edge is naked?
  3. When I get all the edge_list array members that are naked, will they be ordered? If i go through them and connect successively the m_V vertices with the edgelist[x].i and edgelist[x].j indices, will i automatically get the border curve?
I am working on an interesting new plug-in that will be free and I need to solve this…
Thanks a lot!
Milos
http://www.programmingarchitecture.com/
Here is a C# version (using RhinoCommon). Perhaps you can translate this to C++:
https://github.com/dalefugier/SampleCsCommands/blob/master/SampleCsDupMeshBorder.cs
thanks…the translation was pretty simple:
for(i=0; i< mesh.Topology().m_tope.Count(); i++)
if( mesh.Topology().m_tope[i].m_topf_count != 0 && mesh.Topology().m_tope[i].m_topf_count == 1)
ON_Line edgeline( mesh.m_V[ mesh.Topology().m_tope[i].m_topvi[0] ], mesh.m_V[ mesh.Topology().m_tope[i].m_topvi[1] ] );
  mydoc->AddCurveObject( edgeline );
…but…it worked fine for a simple mesh…once i tried a trimmed mesh it went wild (jpg attached) …
What am I doing wrong?
I also tried menno’s advice:
ON_SimpleArray<ON_2dex> edgelist;
int edge_type_partition[5];
mesh.GetMeshEdgeList( edgelist, edge_type_partition );
for(i=0; i<edgelist.Count(); i++)
	if( edge_type_partition[3] <= i < edge_type_partition[4] )
		ON_Line edgeline( mesh.m_V[ edgelist[i].i ], mesh.m_V[ edgelist[i].j ] );
But i just always end up with all edges being drawn…
Thanks!
Milos
Try this:
https://github.com/mcneel/Rhino5Samples_CPP/blob/master/SampleCommands/cmdSampleDupMeshBorder.cpp
