While running the DupEdge command, when I select an edge, it is not highlighted to show my selection. It is selected, but it only becomes highlighted once I finish the command.
«Randy
«Randy
Hi Randy- I believe this is always true, and a known limitation, if the edge is in a block instance - if not, then there’s a bug, I’ll test - thanks for the heads up.
Good to know, but it is not a block instance, I’m my case this morning.
«Randy
Are edges off in the display mode?
Sorry McNeel Guys, it was in an old v4 file and it may be the display. A new vile with build 5A713 works in at least wireframe & shaded. It was someone else’s file and I am rebuilding it. Seems to work fine now. It was my first file with newest build.
«Randy
