After 2 weeks I’m going to assume that nobody is going to answer, and therefore it’s not going to be fixed, I’ll change the code to avoid using DrawObject function.
I understand that you have a lot of work with Rhino 6 Release, but it would have been nice to add it to the bug tracker, or at least answer the post, please if you’re going to fix it just make it known through any channel.
@dale did you make a YT issue for this? I remember we were chatting about this issue right before I left for vacation, but am now having trouble finding the YT issue (or I forgot to make one)
Great, this was probably fixed when we turned off some mesh caching code in RhinoCommon due to other bug reports. We will probably enable this feature again in the future once we determine the source of the bug, but that won’t be until at least SR1.
