Drawing curves: interpolate on multiple surfaces?
interpolate on surface is an awesome command, however, if I have multiple surfaces joined together is it possible to select the entire area to draw curves on?
Hi Ryan - no, but you can try using Drape across the area that you’d like to draw on and create the curve on that single surface, then Pull the result to the polysurface.
did know rhino had this feature! AWESOME
