Thank you very much for the demo. So the twist and transition would always be linear along the length of the curve? In other words, there is no way to have the twist start out slow and increase toward an end?
Pascal, I think in most cases this might get me what i want. I noticed when researching that autocad has a banking option which keeps the rotation along the curve. Is this the default option in Rhino or is this possible as well?
Onetech - great, this was a plan B scenario - i think it will work in most cases for me. Forgive me for my current ignorance - i am at the stage of learning which program will achieve what i want, before i actually learn the program:) … I have a couple followup questions:
How are these additional profiles added and can i ensure they are perpendicular to the sweep profile?
Why is it necessary to delete the original sweep?
When deleting the original sweep, is the original profile curve deleted too?
Would grasshopper be able to do this with a falloff along the length of the curve?
BTW, the projecting curves technique I mentioned just for illustration purposes. In your case three profiles, and Sweep1 or Loft with history will suffice.
Thanks for the link. I only used the initial diagram for illustration as well. The path/curve that i will be sweeping is much more complex and turns back on itself. I will likely have to use your two stage method. I suspect banking or “natural rotation” (as it is supposedly called in AutoCad) would suite my needs - not sure if this is the default for Rhino or optional.
When I do a rail sweep with multiple cross-sections I get the wobbly effect. I played with all the options but i cannot get a smooth transition between profiles. Any ideas?
Hi. For starters you should rebuild/lighten your input curves to get cleaner surfaces. Second: post the 3DM file here if possible, someone will take a look.
