Hi All,
Essentially what I need to do is divide a variable curve; then in each point locate 3 points on both sides spaced 1 mm between them. then extrude those points in a range of .0 to 3 mm. as in the example.
I thought it would be simple but I cannot understand the logic to advance.
additional to this
Can you explain how to group points that are close to each other?
Wow, thank you very much @Jakinta@anon39580149 can you explain the logic to me.
I am currently subdividing the curve into the distances that I need but I still get endless problems and errors. but it looks like you’ve already done it.
:mueca:
You make the job very easy, but since I don’t know the programming, it gets very complicated for me.
Thank you very much, right now I study your solutions.
I would love to know the long answer to understand this work more
I don’t understand your question. But you already know your distances use them .
If you have 8 points with 1mm between them so the length is 7mm, the distance between every 2 groups(8 points) or every 7mm is your choice
