I know you are the best modeler and you can make any type of construction in the simplest possible way. I know that you will do anything for money, but not everyone is like you and can help people who are just getting started in this program. This pain probably comes from the fact that you yourself spent a fortune on training, because of which you did not earn enough to graze on the beach, but you spend this time venting frustration here. I understand if you want to help, but if you have to add very visible comments that criticize me, then do not write here. Go make money on models and lie on the beach for the rest of your life.
Yours concept is good. I am greatfull for your answears and ideas. When i merge your ideas togheter i will get what i want. One surface with moving middle points. I have to figure it out how merge your ideas.
Iâm fed up with this. donât have idea how to create curves here
6.gh (37.8 KB)
Antoosa,
donât know why the network surface, which joseph proposed, didnât work in your file. then would be a one smooth surface than 3 merged.
on the other hand in joseph file i canât create transverse arches.
If you joseph would create map graph with moving middle points it could be done
Versions âaâ and âbâ above divided the edge curves so the section curves were unevenly spaced. This version âcâ fixes that. The âStepsâ slider (yellow group) is the number of section curves. I set it to 48 because it closely follows the ellipse (in front view).
thatâs look good. Almost solved. one more question. is elipse in the middle necessary? Cannot be a curve where i will be able to move in Z direction those points ? Iâm impressed joseph how unconventionally you approach the topic.
This version (âdâ) is an absurd exercise that has sliders in the gray group for creating a yellow NURBS curve down the middle, used instead of the ellipse for shaping the top. It consists of two white points (controlled by two sliders in white groups) with a line between them. Four zero-to-one sliders (âP1â, âP2â, âP3â and âP4â) move points⌠Oh, good luck! The curve is well-formed but limited in shape due to the construction method. Goofy
What can I say joseph, even you were teasing me, you have been responding for every issue. I will add a little bit flexibility to this file (I belive i will do), but you acctualy solve the problem. For me this data tree is mind-blowing and way of thinking impressed me. I hope that you know some more tricks and if I would have a problem you will help me, even if you have to take out your emotions on me because of my incompetence. Thank you
