Hi! I need to divide this curve in a set of Z heights (the onscreen points)? Which component can create a list that can either be plugged into a move or a divide curve? I need al geometry within grasshopper and can’t link any real geometry from rhino. Thank you! !
Hi.
Your pic attached is broken, can you reload it?
Probably with something like mass addiction using partial result will do the trick but i’m not sure if it is the case…
