Distorted display of points
On Grasshopper on Rhino 8, whenever I use Control Points, the points are displayed incorrectly. On the contrary, if I bake them, they are shown properly (I attach a picture). Nevertheless, this is uncomfortable to work with. So, what could I do in order to fix this problem, because in the past, this issue didn’t occur.
Thank you in advance.
Hi JJJ -
In a quick test, I’m not seeing that here.
Please post both the output from the Rhino SystemInfo command and a .gh file that we can take a look at. Remember to internalize referenced geometry and to delete components from 3rd party plug-ins.
Here you have:
Rhino 8 SR19 2025-5-12 (Rhino 8, 8.19.25132.01001, Git hash:master @ 57e3eb280b0f32cbe59f53a554be5e8ffa66fc36)
License type: Commercial, revisión 2025-05-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA T400 4GB (NVidia) Memory: 4GB, Driver date: 5-12-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.24
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-12-2025
Driver Version: 32.0.15.7324
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Renderizado de Rhino” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.19.25132.1001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.19.25132.1001
Distorted_points.gh (11.3 KB)
Hi JJJ -
Thanks.
Your geometry is 4.8 million units away from the world origin. Moving that object to the world origin displays the points in the correct location.
I’ve reported the issue as RH-87912 Grasshopper: Display of FFO Points
I usually work with geometry far fom the world origin and this issue never occurred.
This is the same .gh file, but opened in another PC I own, where the points are shown correctly:
Thank you.
RH-87912 is fixed in Rhino 8 Service Release 33 Release Candidate
Thank you! It came like a breath of fresh air!
