I’m trying to format file names using named Text Objects on Layout pages - unfortunately it breaks if text fields are used in text objects (e.g. %<PageName()>% or custom fields in Document User Text) . I’d prefer to be able to use them as it may be helpful to keep some of these values globally accessible to the users.
I’m getting text objects with sc.doc.Objects.FindByLayer() function and assign their DisplayText property to a dictionary (called here titleblock) and then retrieve them in subprocesses with titleblock.get function (rather than [] subscript in case they were empty).
Is there any part of this process that could be amended to resolve text object’s display text to the correct values?
I’ve tried both DisplayText and Geometry.Text properties with the same results.
These text fields otherwise display correctly in the Rhino document and in the PythonScript debugger.
The error I’m getting is:
Full script (called PrintAllAsSeparatePagesMultiprocess.py):
import Rhino
import scriptcontext as sc
import os
import subprocess
import System.Drawing
def createSinglePDF(view, titleblock):
pdf = Rhino.FileIO.FilePdf.Create()
dpi = 300
settings = Rhino.Display.ViewCaptureSettings(view, dpi)
settings.OutputColor = Rhino.Display.ViewCaptureSettings.ColorMode.DisplayColor
settings.DefaultPrintWidthMillimeters = 0.18
pdf.AddPage(settings)
filename = folder + os.path.sep + titleblock.get("project_number","0000") + "-" + \
titleblock.get("originator", "00") + "-" + \
titleblock.get("zone", "00") + "-" + \
titleblock.get("level", "00") + "-" + \
titleblock.get("drawing_type", "00") + "-" + \
titleblock.get("role", "0") + "-" + \
titleblock.get("drawing_number", "00000") + "_" + \
titleblock.get("latest_revision", "00") + " " + \
titleblock.get("drawing_title_1", "000000000") + " " + \
titleblock.get("drawing_title_2", "") + " " + \
titleblock.get("drawing_title_3", "") + ".pdf"
pdf.Write(filename)
def print_views():
print_chunk_pages_str = rs.GetDocumentUserText("Print_Chunk_Pages").split("--||--")
# cast to integer in case 'if in' below didn't work for strings
print_chunk_pages = [int(i) for i in print_chunk_pages_str]
for view in sc.doc.Views.GetPageViews():
if int(view.PageNumber) in print_chunk_pages:
for object in sc.doc.Objects.FindByLayer("titleblock index-AR002"):
if type(object) == Rhino.DocObjects.TextObject and \
view.ActiveViewportID == object.Attributes.ViewportId:
if object.Name == "Project Number":
titleblock["project_number"] = object.DisplayText
if object.Name == "Originator":
titleblock["originator"] = object.DisplayText
if object.Name == "Zone":
titleblock["zone"] = object.DisplayText
if object.Name == "Level":
titleblock["level"] = object.DisplayText
if object.Name == "Drawing Type":
titleblock["drawing_type"] = object.DisplayText
if object.Name == "Role":
titleblock["role"] = object.DisplayText
if object.Name == "Drawing Number":
titleblock["drawing_number"] = object.DisplayText
if object.Name == "Latest Revision":
titleblock["latest_revision"] = object.DisplayText
if object.Name == "Drawing Title 1":
titleblock["drawing_title_1"] = object.DisplayText
if object.Name == "Drawing Title 2":
titleblock["drawing_title_2"] = object.DisplayText
if object.Name == "Drawing Title 3":
titleblock["drawing_title_3"] = object.DisplayText
# get folder
folder = rs.GetDocumentData("Print", "Folder")
if folder is None:
folder = rs.BrowseForFolder(message="choose location for PDFs - " + \
"once chosen won't prompt for it again, " + \
"can be changed in Rhino - Options " + \
"- Document User Text")
rs.SetDocumentData("Print", "Folder", folder)
# prompt to save the file with the above variable in DocumentUserData
# so subprocesses can use it
answer = rs.ComboListBox(["yes", "no"], message="Need to save the file first, proceed?")
if answer == "yes":
rs.Command("-Save _Enter")
else:
raise Exception('User chose not to save the file - exiting...')
if rs.GetDocumentUserText("Child") is None:
# number of child processes
n = 3
for i in xrange(n):
print_chunk_pages = [view.PageNumber for view in sc.doc.Views.GetPageViews()[i::n]]
print_chunk_pages_str = [str(i) for i in print_chunk_pages]
print_chunk_pages_str_joined = "--||--".join(print_chunk_pages_str)
subprocess.Popen('start /min "" "C:\\Program Files\\Rhino 8 WIP\\System\\Rhino.exe" /nosplash /runscript="-SetDocumentUserText Child Child -SetDocumentUserText Print_Chunk_Pages ' + print_chunk_pages_str_joined + ' -RunPythonScript (C:\\Path\\To\\Script\\PrintAllAsSeparatePagesMultiprocess.py) -Exit No" ' + chr(34) + rs.DocumentPath() + "\\" + rs.DocumentName() + chr(34), shell=True)
else:
titleblock = dict()
print_views()
