Hi All,
I don’t know if there is already a script for that need,
in practice with Py/RCommon I create points/curves objects etc
how could I before creating them, see them in preview and then create them
Thanks. . .
Hi All,
Thanks. . .
public class CsDrawBrepConduit : Rhino.Display.DisplayConduit
public Rhino.Geometry.Brep Brep { get; set; }
protected override void CalculateBoundingBox(Rhino.Display.CalculateBoundingBoxEventArgs e)
if (null != Brep)
e.IncludeBoundingBox(Brep.GetBoundingBox(false));
protected override void PostDrawObjects(Rhino.Display.DrawEventArgs e)
if (null != Brep)
Rhino.Display.DisplayMaterial material = new Rhino.Display.DisplayMaterial();
material.IsTwoSided = true;
material.Diffuse = System.Drawing.Color.DeepPink;
material.BackDiffuse = System.Drawing.Color.HotPink;
e.Display.EnableLighting(true);
e.Display.DrawBrepShaded(Brep, material);
e.Display.DrawBrepWires(Brep, System.Drawing.Color.Black);
To display it →
CsDrawBrepConduit conduit = new CsDrawBrepConduit();
conduit.Brep = breptodisplay;
conduit.Enabled = true;
doc.Views.Redraw();
@farouk.serragedine thanks for reply
I’m new to using RhinoCommon, I’m using it in Python, I try it, but I don’t think I can convert it from C#
Depending on what you need to draw, the CustomDisplay class is quite simple to implement in Python. I wrote a couple of helper functions here that might help:
@AndersDeleuran @farouk.serragedine
I think I have a lot to learn, either way I can’t get them to work. ![]()
Add your code to the post so that I can show you how to integrate a preview in your use case using cc
