Custom preview on python component - minimal example?
I’m trying to understand how to preview geometry that is created in a class object, but is not explicitly output.
Here’s a simplified example of what I’m trying to do.
How can I get the cylinder to show on the first component, without outputting it?
Preview.gh (6.5 KB)
Hi Toni, I shared a bunch of content over here that goes through how to draw things with GHPython, that should help you get going I imagine:
@AndersDeleuran
Thank you for the link. Quite comprehensive package.
If I understood correctly (?), Rhino.Display.CustomDisplay only allows for curve/polyline objects, but works in procedural mode.
For 3D objects using eg. DrawViewportMeshes, would need to switch to SDK mode.
Yup that’s correct. One could probably implement a display conduit in procedural mode as well, but the Grasshopper component SDK drawing methods are likely a lot simpler to implement. For a shaded cylinder, I think you would need to cast to brep and use these two methods:
Though there is also a wire drawing method specifically for cylinders.
Thanks for the link to the gitHub! It took me a couple of hours to understand the preview via python components but when I had your examples I immediately could follow along! Saving my day :pray:
Ah that’s great to hear. Glad it was useful to you :slight_smile:
