In the Display panel, there a red captions for isocurves and edges.
What does it mean, and why red?
First I thought the display mode is not default, but it is (it would be blue then):
Hi
Did you reach any conclusion about the red color?
No, that’s why I asked.
McNeel will know?
I think it has something to do with the two greyed out options below…
With (9.0.26167.11545, 2026-06-16) I can’t either.
Sure.
Seems it “self healed” in (9.0.26167.11545, 2026-06-16).
Hi
It has reappeared in the latest version.
Not for me this time…
It must be possible to find out what causes this, a caption backcolor does not turn red without the color being explicitly set.
This is specific to Wireframe mode and occurs repeatably if Surface Isocurves and Surface Edges are both unticked.
It does the same thing in R8.
Yes, then it’s red in here as well.
Never noticed.
Ah, now I finally understand!
If Surface Isocurves and Surface Edges are both unticked, then you wouldn’t see a surface.
The red is a warning.
Makes sense to me.
Means, the red caption are not an error, all is good.
Hi
I think it’s a bug because it only appears when the left and right sidebars are hidden.
In Rhino 8, this doesn’t happen when the left and right sidebars are hidden.
In here that has no influence.
Then the bug is that it is NOT red.
But here the sidebar status doesn’t matter, work as expected.
In any case, in Rendered the red mechanism is not the same as in Wireframe.
Now I don’t have it in Rendered anymore, which I think it should.
