here is the function where the conduit is called:
def buildRules(shapeList,topos,sShapesIn ):
addShape = False
shapeRuleAddData = rs.ListBox(shapeList, "Select Shape to Add Rule", "NT_vTools v1")
if shapeRuleAddData is None:
return None
shapeRuleAddDataTok = shapeRuleAddData.split(" " )
if shapeRuleAddDataTok[0] == "Add":
return None
rulesExistAlready = True
if test<3: rulesExistAlready = False
shapeNum = int(shapeRuleAddDataTok[1])-1
cTopo = rs.coercebrep(sShapesIn[shapeNum])
vData = Rhino.Geometry.VolumeMassProperties.Compute(cTopo)
bBox = cTopo.GetBoundingBox(False)
len = bBox.Diagonal.Z
vec = Rhino.Geometry.Vector3d(0,0,len)
center = vData.Centroid
##DISPLAY CONDUIT!
ptStart = center
ptEnd = Rhino.Geometry.Point3d(center.X,center.Y,center.Z+len )
line = Rhino.Geometry.Line(ptEnd,ptStart)
screenSize=0
worldSize=0.5
conduit = DrawArrowHeadsConduit(line, screenSize, worldSize)
conduit.Enabled = True
scriptcontext.doc.Views.Redraw()
#rs.GetString("Pausing for user input")
#GET NEW OBJECTS
objs,units = getRule(topos,shapeNum,rulesExistAlready)
conduit.Enabled = False
#test = shapeRuleAddDataTok.Count
test = len(shapeRuleAddDataTok)
if objs == None:
return [None, None, shapeList,False, False, units]
if not rulesExistAlready:
shapeList[shapeNum]= shapeRuleAddDataTok[0]
else:
rulesAdded = shapeRuleAddDataTok[1].split("(")
rCount = int(rulesAdded[1])+1
shapeList[shapeNum]=shapeRuleAddDataTok[1] + " ("+str(rCount)+" added)"
return [objs, shapeNum, shapeList,True, False, units]
& the conduit is a simple arrow display:
class DrawArrowHeadsConduit(Rhino.Display.DisplayConduit):
def __init__(self, line, screenSize, worldSize):
self.line = line
self.screenSize = screenSize
self.worldSize = worldSize
def DrawForeground(self, e):
e.Display.DrawArrow(self.line, System.Drawing.Color.Red, self.screenSize, self.worldSize)
Also, here is a modified version of the entire code i’m running – the error is happening @ line 182
import Rhino
import System.Drawing
import scriptcontext
import System.Windows.Forms
import math,time
import System
self.line = line
def main():
section = "NT_vTools"
rExist = False
objData = rs.GetDocumentData(section)
if len(objData)!=0:
rExist = True
rules = []
topos = []
shapeList = []
units = []
if rExist:
topoCount = int(rs.GetDocumentData(section,"T_count"))
sShapesIn = []
for i in range(topoCount):
rules.append([])
tEntry = "T-"+str(i)
shapeIn = System.Guid(rs.GetDocumentData(section,tEntry))
sShapesIn.append(shapeIn)
shape = rs.coercebrep(shapeIn)
topos.append( [shape.Vertices.Count, shape.Faces.Count])
ruleCount = int(rs.GetDocumentData(section,tEntry+"_count"))
if ruleCount==1:
shapeList.append("Shape "+str(i+1)+ " ("+str(ruleCount)+" rule added)")
else:
shapeList.append("Shape "+str(i+1)+ " ("+str(ruleCount)+" rule's added)")
for j in range(ruleCount):
rEntry = tEntry + "_R-"+str(j)
datain = rs.GetDocumentData(section,rEntry)
tokData = datain.split(",")
ruleObjs = []
for k in range(len(tokData)):
ruleObjs.append(System.Guid(tokData[k]))
rules[i].append(ruleObjs)
shapeList.append("Add New Topology")
else:
sShapesIn = rs.GetObjects("select Seed Shapes",rs.filter.polysurface)
if sShapesIn is None: #error Checking
print "forgot input"
return
for i in range(0,len(sShapesIn)):
shape = rs.coercebrep(sShapesIn[i])
shapeList.append("Shape "+str(i+1))
rules.append([])
units.append([])
while True:
objs, data1, nShapeList, addRule, endBuild, nUnits = buildRules(shapeList, topos,sShapesIn)
if addRule:
rules[data1].append(objs)
if nUnits:
units[data1].append(nUnits)
shapeList = nShapeList
elif objs == None:
else:
rules.append([])
units.append([])
topos = data1
sShapesIn.append(objs)
if endBuild:
break
totalTopos = len(sShapesIn)
rs.SetDocumentData(section, "T_count",str(totalTopos))
tCount = 0
for rulesInType in rules:
RuleEntry = "T-"+str(tCount)
rs.SetDocumentData(section, RuleEntry,str(sShapesIn[tCount]))
totalRules = len(rulesInType)
rs.SetDocumentData(section, RuleEntry+"_count",str(totalRules))
for i in range(totalRules):
entry = RuleEntry + "_R-"+str(i)
strRuleGuids = str(rulesInType[i][0])
for j in range(1,len(rulesInType[i])):
strRuleGuids+=","+str(rulesInType[i][j])
rs.SetDocumentData(section, entry,strRuleGuids)
tCount+=1
print "saved"
#buildRules(shapeList, topos)
addShape = False
return None
return None
##DISPLAY CONDUIT!
ptStart = center
#test = ptStart + vec
screenSize=0
worldSize=0.5
#GET NEW OBJECTS
if objs == None:
else:
#buildRules(shapeList,topos)
def getRule(topos,shapeNum,rulesExistAlready):
topo = topos[shapeNum]
def cp_filt1(rhino_object, geometry, component_index):
iscpFilt = False
topoCheck = [geometry.Vertices.Count, geometry.Faces.Count]
if topo==topoCheck:
return True
else:
return False
def cp_filt2(rhino_object, geometry, component_index):
iscpFilt = False
if topoCheck in topos:
return True
else:
return False
objs = []
units = None
getUnits = True
if rulesExistAlready:
msgBox = rs.MessageBox("add additional mesh unit types?", 4, "NT_vTools v1")
if msgBox == 7:
getUnits = False
if getUnits :
units = rs.GetObjects("select Unit Curves, Pts, &/or Meshes"+str(shapeNum+1), rs.filter.curve+rs.filter.point+rs.filter.mesh)
if units is None: #error Checking
print "no Units input"
baseShape = rs.GetObject("select base shape -- RULE "+str(shapeNum+1),rs.filter.polysurface,custom_filter=cp_filt1 )
if baseShape is None: #error Checking
return None
objs.append(baseShape)
children = rs.GetObjects("select base shape Children -- RULE "+str(shapeNum+1), rs.filter.polysurface,custom_filter=cp_filt2 )
if children is None: #error Checking
return None
objs.extend(children)
return [objs,units]
if( __name__ == "__main__" ):
main()
