In Rhino 5, when you move an object (in this case, a simple circle with a line in it), the outline of the object in yellow appears as the object is moving across the screen.
However in Rhino 6, what I have found is that when an object is selected, grouped, CLICKED OUT, then clicked on again and moved, this outline (which is now a light grey dashed line) disappears. However, if it is selected, grouped and moved, all in one shot, the outline will still be there. I’m not sure if this is a bug, so I was wondering if there was any way to make the outline persistent throughout as sometimes reference is needed while moving. Thanks!
