Dimensions
In the old version the dimensions were present, this is very important
Hi Jon,
These dimensions were just a display hint that appeared while you move the cursor over the walls. We decided to remove this feature, as it may slow the cursor in big files.
You can create dimensions or use the Distance if you want.
Regards,
Enric
Hi, would it be possible to create dynamic dimensions for walls as seen in Revit? I’m talking about those that show up when a wall is selected and tell the distances to nearest parallel walls and objects. Editing and placing walls would be much more convenient with it.
Maybe the cursor wouldn’t cause problems if the feature was activated upon selecting a single wall (or any object).
i need this too
A lot needed tool
