Dimensions style from imperial to Metric?
For work I have to use imperial, but for personal projects i work in metric. I have a dimension style in imperial I’d like to use in metric. I imported and the scale is all wrong. Is there an import option or a global multiplier I an assign so the scale is correct?
It depends on what you want and how you’re going about it.
Why not use the Alternative units option and show both?
Another option is to apply a length factor in the annotation style Length units configuration:
I forgot about Alternative units, and that could be useful. However, I do want to avoid clutter. I was hoping for a way to get a metric equivalent without recreating everything in metric. I’ll look into the length factor.
