Dimensions in VaPlan
Hi all,
I can’t seem to find a solution for the following. I am working on a one level plan. In my 3D model I drew the grid lines and put measurements (all on z=0). When I make a plan out of this, I do get the grid lines, but not the measurements. Are you supposed to measure the plan-export, instead of the 3D model? I tried to adjust clip-heights and stuff, but that did not help.
thanks!
@isolabella The VisualARQ plan view command doesn’t generate Rhino dimensions or other annotations. You need to draw them on top of the 2D plan view.
But rather than creating a plan view with the vaPlanView command, you can print the 3D model shown in plan view using the Hidden display mode. This video shows how it works: https://youtu.be/1qdNB5v_fwE
That way you can include the dimensions and annotations on the 3D model and print everything to vector output:
