DimAngle doesn’t allow to select line from specific detail
Dear all,
i have encounterde a Bug where I cannot select any lines from a specific detail using the DimAngle command:
I have tried the same file on a different workstation with the same result. Other details windows
work fine with the same geometry. Can someone replicate this problem?
Dachverglasungen Rahmen___.3dm (2.6 MB)
Hi Peter -
Yes, thanks. As you say, other details work fine.
I can’t reproduce this from scratch but I’ve put this on the heap to be looked at
RH-84133 Annotation: DimAngle: No Selection on Detail
Do you know how this detail was created? Or do you have a way to reproduce this in a new file?
The “original” Detail window “FE3” was simply created by the command line:
_Detail _Add → two points picked
The original detail just worked fine and there is still an angular dimension on the page. Later I copied the complete layout page 5 times. Not sure when, but at some point the detail starts bugging. Also the original detail window doesnt work any more.
RH-84133 is fixed in Rhino 8 Service Release 13 Release Candidate
great folks! :hugs:
I’ve hit the same / similar issue in Rhino7 will there be a fix for that?
Hi David -
No, we are not releasing new versions of Rhino 7 at this point.
