Differential Growth (Blender Add On like)
Here are some examples done using Differential Growth
Example 1
differential growth 1.gh (21.3 KB)
Uses this gradient
gradient_rhino
Example 3
Render with Cycles and Glass with a Sun and not too much Environment
differential growth 3.gh (9.9 KB)
Links
There is a first version of tool in Nautilus 1.9.9.3. It replicates quite exactly the code of the AddOn for Blender by Boris Okunskiy, but there are some changes. It is a quite hard tool to use, I will surely make new versions.
It needs a weighted mesh and as it doesn’t really exists in Rhinoceros, I used UV for the weights. Weight of 1 on vertex will enable the vertex to Growth. I use the U value, there is a Disk Component that outputs a good Mesh
In blender component the noise Vector Field is hard coded, in my tool you can plug whatever Vector Field.
As I didn’t have a version that works like in Blender (using Blender Geometry, replacing it with new ones, using History) I outputs all the mesh results.
There is a time limitation (in seconds) and a calculation button.
This is something else! Looks amazing.
This is beautiful!
Wow, thanks for your fascinating work — this looks truly amazing!
Btw I’m Boris Okunskiy, the author of the above-mentioned Blender Add On. My work was also based on the work of others in the field — and I’m glad that it helped you, and hope it will help others too :heart:
