Hi all,
Using Rhino 5:
I have a script which works fine in the editor as a script but as soon I run it as a command it stops behaving as expected. The result of the script is the same but the ability to escape and the updating of the command prompt does not work. I think it is to do with the while loop being too tight and the Rhino.rhinoapp.wait command not “waiting” enough? Any Ideas?
import scriptcontext
import Rhino
__commandname__ = "ExplodeMesh"
def makeNewMesh(mesh):
print "Starting to Split Mesh"
rs.EnableRedraw(False)
faces = rs.MeshFaces(mesh,True)
i = 0
bEsc = False
total = len(faces)
while i <= total-1:
Rhino.RhinoApp.Wait()
if scriptcontext.escape_test(False):
print "ESC Pressed Objects Locked"
bEsc = True
break
percent = int((i/total)*100)
Rhino.RhinoApp.SetCommandPrompt("Exploded: " + str(percent) + "%")
a = faces[i]
b = faces[i+1]
c = faces[i+2]
d = faces[i+3]
if c[0]==d[0] and c[1]==d[1] and c[2]==d[2]:
rs.AddMesh([a,b,c,d], [[0,1,2,2]])
else:
rs.AddMesh([a,b,c,d], [[0,1,2,3]])
i = i + 4
if bEsc == False:
Rhino.RhinoApp.SetCommandPrompt("Exploded: 100%")
print "Split Mesh into " + str(int(total/4))
rs.DeleteObject(mesh)
else:
rs.LockObject(mesh)
rs.EnableRedraw(True)
return 0
def RunCommand( is_interactive ):
mesh = rs.GetObject("Select Mesh to explode",32,True,True)
if mesh == None:
return None
current = rs.CurrentLayer()
meshLayer = rs.ObjectLayer(mesh)
rs.CurrentLayer(meshLayer)
ex = Rhino.Input.Custom.GetObject
makeNewMesh(mesh)
rs.CurrentLayer(current)
return 0
