Diamond grid surface - dormers
Hi all,
I am working on a building with a structural dome facade, the facade has triangular panels and the windows are essentially where there is no surface.
i need to somehow turn the top floor windows into dormer style windows,
i tried this with list item and moving the vector in z axis however no luck, Could anyone please help me with this, it would mean a lot.
ill attach my script,
Red bellow is a segment of the dome without any dormers yet.
If anyone does take the time to help me id appreciate it so much but you have to set 2 curves for the sweep inside rhino
triangle glass facade2.gh (31.6 KB)
here is a sketch to describe what im after
Please let me know if anyone can help
Best regards,
Geordy
And it looks like you didn’t internalize the two rail curves?
Hi Joseph,
I have the lunchbox plug in for the diamond grid on the surface, this make the triangles,
ill be honest I’m not sure what to do with the curves,
the reason i set them in rhino is because i have to make many different curve shapes ( its for an irregular building )
so in order to preview the result of the grasshopper script, you have to make 1 curve (in rhino) and then make another curve (in rhino) that’s around 15000mm higher in the z axis, then assign the 2 curves to the grasshopper cells
Did it make sense what i was trying to explain about the dormers?
Best regards,
Geordy
Hi Geordy -
When plug-ins are required in a Grasshopper definition, please always say so up-front so that other that don’t use that plug-in don’t unnecessarily spend time downloading the file and reading the task description.
No. You need to internalize the curves in the Grasshopper components. Right click → Internalise data.
Dear Wim,
Im very sorry, I didn’t understand this to be a rule however it makes perfect sense. i know for the future now.
I’m relatively new to the forum and grasshopper so its all a bit confusing,
here is the script with the curves internalized.
please let me know if anyone is able to help me
triangle glass facade2.gh (37.8 KB)
Best Regards,
Geordy
Or @Geordy could internalize the output of the lunchbox plugin, so those who don’t have it might be able to contribute toward a solution.
Thankyou for showing me how to internalize this, i didn’t know this was possible,
I have tried, is this what your after?
I’m aware the cells aren’t visible but wanted to make clear that on the right is the internalized data
triangle glass facade2.gh (101.0 KB)
Best Regards and i appreciate any time people are taking to have a look at this,
-Geordy
Hi All,
Has anyone Managed to understand how to manipulate the script to move the top windows into dormer type windows?
Best regards,
Geordy
