Hi all,
here is a script to flatten all child layers so that no more nested layers are present.
Everything works well except that scriptcontext.doc.ActiveDoc.Layers.Delete(lay.Id,True)
does nothing if a object is moved to another layer before.
I guess i miss something simple maybe commit changes to the layer.Table…dont know.
I descriped the problem in big letters on the line wehre nothing happens.
import scriptcontext as sc
act_doc = sc.doc.ActiveDoc
# iterate over layers
for lay in act_doc.Layers:
# get all child layers
if len(str(lay).split('::')) > 1:
# check if objects on this layer
if len(act_doc.Objects.FindByLayer(lay)) > 0:
# move objects to the first parent layer
for obj in act_doc.Objects.FindByLayer(lay):
lay_first = act_doc.Layers.FindName(str(lay).split('::')[0])
obj.Attributes.LayerIndex = lay_first.LayerIndex
obj.CommitChanges()
# delete the child layer
# HERE IS THE PROBLEM THE LAYER WILL NOT BE DELETED
# ONLY IF THE SCRIPT RUN A SECOND TIME
# BUT THAN ITS THE ELSE STATEMENT
act_doc.Layers.Delete(lay.Id,True)
else:
Maybe someone had the same issue and a solution for it.
Thanks in advanced
