rs.DeleteObject with object in locked layer?
I’ve found that rs.DeleteObject won’t delete object in locked layer. Do I always have to programmatically check whether a layer is locked? It gets quite complex when the layer is nested in another layer, since rs.LayerLocked won’t work either. Any workarounds?
Thanks!
Something like this should work (try it with a layer called “LockedLayer”):
import scriptcontext as sc
objIDs=rs.ObjectsByLayer("LockedLayer")
if objIDs:
    for obj in objIDs: sc.doc.Objects.Purge(rs.coercerhinoobject(obj))
    sc.doc.Views.Redraw()
–Mitch
Hi @Helvetosaur
According to the SDK, Purge
Removes object from document and deletes the pointer. Typically you will want to call Delete instead in order to keep the object on the undo list.
However, I still want to be able to keep the object on the undo list. Is there a way I can better manage the locked status of a nested layer?
Thank you!
I’ve also noticed that rs.Add series work well on locked layers. I don’t quite get the rationale to not be able to delete objects from locked layers.
For that I think you would need to unlock the layer in the script, delete the object, then lock it again… --Mitch
I guess it just assumes that objects or layers are locked for a reason and that you don’t want to delete them… That being said, @dale @stevebaer it seems to me that this is a good candidate for an additional optional argument to DeleteObjects()…
rs.DeleteObjects(objs, DeleteLocked=False)
Would work like now if no argument or False was specified; if the DeleteLocked flag is set to True, then objects that are locked or on locked layers are allowed to be deleted…
–Mitch
I think that keeping objects from being accidentally deleted is pretty much the main reason for having a layer locking feature. I also think that from a scripting point of view there is practically no difference between your unlock/relock scheme and the DeleteLocked option scheme, with the exception that the unlock/relock scheme is probably less programming accident-prone and easier to notice bugs.
Well, I’m not sure about that… One thing I don’t like is if the user aborts somewhere in mid script, that layers that were locked are left unlocked… Adding an additional argument to DeleteObjects that you have to expressly set in order to delete objects seems to me to be a good way to deal with this.
–Mitch
Hi Mitch,
This has been requested before and already added to RhinoScript WIP (both DeleteObject and DeleteObjects methods now have a blnIgnoreModes switch). Not sure if RhinoscriptSyntax / Python methods were updated yet.
–jarek
I’ve added a wish list item for this:
https://mcneel.myjetbrains.com/youtrack/issue/RH-37351
In the mean time, if you are using the Rhino WIP, you can use these:
def DeleteObjectEx(object_id, ignore_modes=False):
    rc = False
    object_id = rs.coerceguid(object_id)
    if object_id:
        rhobj = rs.coercerhinoobject(object_id)
        if rhobj: rc = sc.doc.Objects.Delete(rhobj, True, ignore_modes)
        if rc: sc.doc.Views.Redraw()
    return rc
def DeleteObjectsEx(object_ids, ignore_modes=False):
    rc = 0
    object_ids = rs.coerceguidlist(object_ids)
    if object_ids:
        for id in object_ids:
            rhobj = rs.coercerhinoobject(id)
            if rhobj and sc.doc.Objects.Delete(rhobj, True, ignore_modes): rc+=1
        if rc: scriptcontext.doc.Views.Redraw()
    return rc
– Dale
Rhino WIP is Rhino 6, right? Can I replace the Rhinocommon.dll file with a higher version to get it work?
Yes.
Sorry, no.
Hi @dale, seems there is a same issue with doc.Objects.Replace() for objects on locked layer. In C#, objects cannot be replaced if they are on a locked layer. That’d be great if you could add the same mode check for doc.Objects.Replace().
Thanks.
Hey @mingo1214 - I’ve logged your request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-64703
– Dale
Does this work in rhino 7? I am trying it and apparently not…
I would like to delete all the block instances on hidden layers and maybe locked with a python scirpt,How can I do it?
Yes
Can you post a small code sample that doesn’t work for you?
– Dale
