Deleted Grasshopper plugins by mistake, Rhino 7 Macbook Pro
In order to clear my very full MacBook Pro for files, I have mistakenly deleted some grashopper files. I have Rhino 7. Is there any solution to this that doesn’t involve deleting and reinstalling the whole program? Square, division, Circle, Expression, Boundary Surfaces, cull pattern, smaller than , all theese just show up as blanks when im opening a file. It didnt help to update to another version, havent had problems with Rhino yet, just grashopper. Attempted package restore, got this message: 404: No package found by the name of ‘Grasshopper’.
Failed to install the missing plug-in.
Not all plug-ins were found on the package server.
The missing plug-in(s) may be available at https://www.food4rhino.com. Dont really know what to do now.
Thankful for any advice on this.
Suggestion:
If you have a second computer with Rhino available. Then open the file you have on that computer. The screen with all the missing plugins will popup. Take a picture/printscreen from that.
Use this to update your missing plugins on your first computer. That should bring you very close to your original setup.
(do not ask me how I know :frowning:
regards, Eef
Hej Anne Marte -
I’m not sure what that means since Rhino 7 isn’t updated all that often anymore, but anyway…
You could try the following:
  1. Exit Rhino
  2. Rename the ~/Library/Application Support/McNeel/Rhinoceros/7.0 folder to, e.g., include -backup after 7.0
  3. Install from a freshly downloaded DMG
  4. Start Rhino
Does that make a difference?
Yes! Thank you!
Thank you for posting, didnt have a second computer with Rhino unfortunately
now this shows up again and i dont dare to delete anything..
Hej Anne Marte -
The more interesting part of the path is clipped in that picture.
You can make that dialog wider to see the entire path, like this:
Can you post the complete path of both of those components?
I cant drag the frame to show the path but if i click the icon, it shows me the file located in Rhino7-Contents-Frameworks-RhCore.framework-Versions-A-Resources-ManagedPlugins
Hej Anne Marte -
They can’t be both in the same location. What is the other path?
The other one is here: Rhino7-Contents-Frameworks-RhCore.framework-Versions-A-ManagedPlugins-GrashopperPluginrhp-Components
