Delete subdivided points
dl
dl.3dm (893.5 KB)
It is better to directly delete the subdivided points and get the result of the right figure
stitch it to the adjacent point on that edge- problem solved. stitch
Yes, but it takes more time. Supporting direct deletion will be efficient
unless that point is connected to an edge, then you just chase the problem around the model. stitching gives it a definite ending point.
to be clear, you can delete points… they just have to resolve naturally if they don’t you have to resolve them yourself.
For some reason that one does not and you have to stitch it.
