Delaunay connection between multiple curves
It is a classical problem, You will need Ball Pivot.
After this “coarse” meshing I invite you to test the QuadRemesher in the Rhino 7 Wip and then why not SUbD
I advise you to make isocurves in 2 others axes. Then feed points the RhinoCommand MeshFromPoints
Then QuadRemesh
