Defining InletOutlet in Eddy3D Indoor Simulation with a Single Window
I’m currently working on an indoor simulation using Eddy3D, following the indoor example setup. My model only has one window, and I’m unsure how to define the inlet and outlet in this case. Should I use the same geometry (the single window) as both the inlet and outlet? Is this a valid approach, or do I need to handle it differently? Any advice or examples on setting up a single-opening indoor simulation would be greatly appreciated!
Thanks in advance for your help!
You could look into a whole-domain simulation approach, if you don’t have inlets and outlets properly defined?
More info here, see page 15 ff.
Thank you for your previous suggestion. However, for my current research, I am trying to explore whether a domain-decoupled indoor simulation approach could work in a simplified but reasonable way.
My current case includes a whole floor that has around 48 external windows facing different directions. This works for a simple case with one inlet and one outlet. However, when I include all classified inlet and outlet windows for the full floor(classified by direction), the indoor probing results become unstable or invalid.
I would like to ask whether this decoupled boundary assignment is reasonable for a full-floor case with many openings, or whether a whole-domain approach would be strongly recommended. Also, should I include all wind-facing/leeward windows as inlet/outlet patches, or select only a smaller number of dominant openings?
Any advice would be greatly appreciated.
Thank you!
