Hi!! I am having the same issue as before when I give thickness to a subd, some defects shows like this.. one user here did the same method in rhino8 and it worked perfectly.. I dont know if it is because I have rhino7.
Anyways.. Can someone who is using rhino8 make an offset "outwards’’ to these files and attach it here
, they have the same object but with different scales. ( For 1:200 and 1:450 scale, offset is 2mm), and for the real scale file 0.2 m. Thank you
1;200 scale bridge.3dm (720.1 KB)
Real scale bridge.3dm (837.3 KB)
1;450 scaled bridge.3dm (18.6 MB)
