Deconstruct Brep Adds more Surface
I use Deconstruct Brep option to create surface from the Extrusion brep. But for some reason instead of getting 4 Surfaces I am getting 8 Surfaces as shown in the attached picture.
BR,
J.Randeep
hello!
first of all, I see that you are new, so have a look at this:
it will help you get more help. There is an etiquette as to how to ask questions in this forum and believe me it works, take the 10 minutes and go through it.
secondly, It doesn’t show what you are feeding into extrusion. is it a surface? a curve? It would all be easier if you uploaded the file.
Also highly recommend switching Fancy Wires on via the menu, it really helps you to find problem with data structure.
Please find the attached I have Internalised the data from the excel, I hope that is OK.
2_Brep Deconstruct Brep Adds More Surface.gh (24.8 KB)
BR,
J.Randeep
Looks like you are using Polyline with closed option… that is the cause of the invalid curve…
2_Brep Deconstruct Brep Adds More Surface_re.gh (24.4 KB)
Thanks for the advise.
BR,
J.Randeep
