Custom geometry fixated exactly on control points
I am trying to create a generative landscape based on an actual .dwg topographical data. I have a mesh that I want to fix exactly on the parametric control points I made along the terrain. I have tried different nodes on grasshopper (curve array, flow, etc.) but i just could not fix the geometry on the exact points that run along the curve. What would be the best way to achieve this? Thank you.
terrain test help.zip (3.1 MB)
