Custom EPW file import in Ladybug Grasshopper from PC folder
Hello! I am surviving some kind of a crisis here:)
The aim of my research is to compare the two summer temperature scenarios (the current situation VS the R.C.P. 4.5 projection to the 2050). I managed to successfully modify existing EPW file with “R studio”, and from the excel visualization all the modified data seems to be accurate.
The major problem I am having now, is how to import the modified EPW from my directory folder to the grasshopper ladybug canvas. From the information I have now, it seems that it is only possible to upload the HTML link from open sources to Ladybug, and there is no evident way on uploading it immediately from the PC.
I sincerely hope that there is an evident or banal solution for this problem that I missed!
Please, let me know if there is a solution of any kind!
Thank you!
Best regards,
Anastasiia, the saddest sustainability student
Hi Anastasiia -
Please see https://discourse.ladybug.tools/ for questions related to the Ladybug Tools.
Hi @Anastasiia1
You just can use the grasshopper native “file path” component
For questions about LBT you can better use the Ladybug folder as @wim showed.
Thank you! Will do
Thank you! The problem is that the ladybug “import epw” component gives the following error: “1. Solution exception:index out of range: 1”, which makes me think or about the epw file integrity/structure (even if I tried to connect the original unmodified file as well with the same result), or about the way ladybug reads the file path format.
On the other hand, the “LB download weather” requires an URL, and the folder where to save it, so this one I can’t use for my aim.
I attach the screen.
Thank you for your time, I will ask on the ladybug community as well.
