Hi, guys! Could u please help me to find out such a plugin for grasshopper which can form a checklist where branch number is a headline and each index is under its headline (as in picture). as it is on the list. Or, if there is no such a plugin how I can create it, and what I need to accomplish such stuff.
For a more clear picture of my mind, I’ve made an example of what I need in grasshopper, by replacing imaginary plugin with the image of how I see it should be.
Thanks in Advance!
thanks for reply, AndersDeleuran. Your suggested method is not suitable for my issue. I need more advanced tool. for example like Heteroptera’s Pick item plugin, but more detailed… if u noticed I need automatic input, but value list has only manual data input…
thanks for ur reply, seghierkhaled, the problem is that there is no branch identification and we don’t have opportunity uncheck all branch in one click. The lack of identification does not issue in this specific example but when u have a bunch of branches and objects in them u could make mistakes so often.
I don’t know if there is a component like what you want but actually you can use Heteroptera item pick and it have 3 options: Check-list,list-item, tree-item
when you check items you can switch to list-item and check the first item to uncheck all other item in the same tree than switch back to check-list
Seghier khaled, great, I am also right on this way, and now I am thinking about how to give a special name to my groups and items in it, do u have an idea?
Hi, Amin! Thanks for ur reply and special development of ur plugin! U R the Best! one more question: is it possible to replace branches and index numbers to special names if needed?
