Curve Self-intersecting
At times, I face a strange curve self-intersecting exception that occurs with the same curve in one location but not in another. For instance, with this plain shape originally created at the 0 XY world origin, there was no self-intersecting. However, when moving the same shape to a different location, self-intersecting can occur or may not. In this example, the shape is located at the spot where self-intersecting occurs, but shifting it a little to another position makes the self-intersecting disappear.
Yes there are solutions, but it occurs often and without understandable reasons, more over the issue severely affects on the productivity of gh “boundary surface” component.
Shape.3dm (3.5 MB)
explode the curve and use “SelSmall” command
or “IntersectSelf” to show intersection point then explode curve
you can find a very small arc in the red arrow
delete it, join curve again and you are good go to
I believe this reason is understandable enough
Thank you @11165 for your reply, but if you move the shape a little bit, the intersection disappears. The question is, why does the self-intersecting happen at some positions and not others with the same curve?"
Hi @sadovshikov ,
Could you give exact instructions on how to create the curve, exactly as you created it? I’d like to follow the process through, to test a theory.
Thanks
Jeremy
the arc is too small, that it is in the same level as “document tolerance”
or smaller level.
modern PC use binary and numbers too large or too small will cause problems.
it would be a very long story to expand the whole knowledgebase.
take away: avoid extremely small or large number in your file.
your model tolerance is 0.001mm
which makes it impossible for rhino to determine if this small arc intersect with its nearby line.
sometimes it may calculate as intersect, sometimes not.
operation in this number range would be absolutely unstable and has no meanings.
Thank you, I have got the idea of what the reason can be. I have uploaded the definition, which is pretty simple and should not cause self-intersection, but anyway, some components do it…
this is what double number 0.2 store in our PC as binary.
we can not even make a fine 0.2 in PC because we use binary.
so that is why every software in PC has tolerance. (some of them can be set by user)
without tolerance, we can not even operate basic operation as 0.2+0.2=0.4
The real issue is that the small arc should not be introduced by Grasshopper in the first place - there is no need for it.
You can bake the results of the last three gh building components (Connect Ends, Region Union and Fillet) and, in Rhino, analyse the geometry at each stage. You will find that the first creates 12 segments as you would expect (3 x 4), the second creates 18 segments (3 x 6) as you would expect and the third creates 25, ie one more than the 24 expected (3 x 8). The extra segment is the micro arc referred to above.
So this extra curve is introduced by the Fillet component and it occurs at the opposite end of a curve to the end affected by the fillet. I can see no reason to recalculate the unaffected end - it should surely simply copy the original position (which coincides with the end of the next segment, which is of course not acted on by the fillet). To my mind this is the result of a bug in the gh Fillet component. (? @DavidRutten)
Building the curves in Rhino demonstrates that Rhino’s fillet results in 24 segments - i.e. does not exhibit the same error.
Test.3dm (62.0 KB)
Regards
Jeremy
Superb thorough scrutiny! :+1:
