I need to find points and their distances perpendicular to the main curve along certain distances.
I can’t use Curve Closest Point because it looks for a distance perpendicular to the curve, I need a distance in a defined plane. I wanted to achieve this using Perpendicular Frames and Curve | Plane, but the problem is that the component doesn’t find all the (obvious to me) intersections.
I have tried other approaches as well:
- replacing planes with planar faces
- interpolation of the curve on which I am looking for intersections
- curve extrusion - intersecting curves with planes - starting points of curves
What am I doing wrong? Is there a better way to achieve the result?
curve_plane_intersection.gh (11.9 KB)
